My 1972 MWB Soft Top - 350 Chev Project
- Been thanked: 19 times
Hi all, just arrived here whilst searching for advise... damn I've missed forums,
From Melbourne Australia...
Anyway, just purchased this 72, it had been working on a farm unregisterd for the last 15 years in Canberra Australia, someone did a 350 chev conversion a long time ago, it has almost zero rust,
The plan is to strip it down, rebuild the engine, probably go to a 2WD and a turbo 350/400, I have a diff out of a chev truck to go in, Tidy up the body and re paint in and out and end up with a good summer cruiser..
First off was to remove also the stuff that had been added on over the years, then remove the body from chassis and pull the motor and trans, so I can get the rolling chassis to the sand blasted and get it blasted, epoxied and re painted
I'll post photos as I go,
How I purchased it
Day 2; Got it home and remove a lot of the old stuff that had been added
Day 7; Body off, a few hours of pressure washing
How I purchased it
Rock On!
- Has thanked: 7687 times
Re: My 1972 MWB Soft Top - 350 Chev Project
Welcome to 60Patrol!
Looks like a fun project. Have fun and keep us posted!
Looks like a fun project. Have fun and keep us posted! Beyond any hope for intervention
Busy couple of days, removed engine, trans & shocks..
Also removed the doors and 50 years of added on screws & bolts
Chassis can go off to the blaster now, blast, epoxy then paint,
Body will go to media blast and then into epoxy before body work
Rock On!
Chassis all tidied up and off to the sand blaster
Started a playlist on youtube that i will keep adding to for anyone interested
https://youtube.com/playlist?list=PLuW0 ... 4OCEHlu9Ep
Rock On!
Nice work. What type of sealer or coating or you planning to use after it's sand blasted?
I'll be using Satin black KBS RustSeal, recomended by my paint & panel guyRiverPatrol wrote: ↑Mon Jan 12, 2026 10:38 am Nice work. What type of sealer or coating or you planning to use after it's sand blasted?
KBS RustSeal is a single component high-solid content, rust preventive coating / rust paint / sealer. It is impervious to road salts and almost every chemical. RustSeal self levels out to a smooth rock-hard finish that resists chips and scratches.
https://www.kbs-coatings.com.au/product/rust-seal/
Rock On!
Sounds like that will do the job well.
Chassis back from blasting and painted
Rock On!
Also some powder coating back
Rock On!
