Tune up specs & parts search
Locked
Post by npca-denny »
Hi , I am looking for the point gap, dwell, & timing settings for a 67 patrol w/ stock engine. Also what / where you can find points.      I am searching for a hard top, pair of front doors, upper half of rear doors, Windshield hinges, tail lights.    I am in Portland , OR  area.     (503) 829-8488  shop     (503) 824-2438  home    try shop first. If not there please leave your name & phone #           Thank you   Denny
Post by npca-grant »
Hey Denny   I dont have the point gap settings with me at the moment, Im sure someone can chim in with them. If not, email me at grantsenn@yahoo.com and Ill look them up for you. As for points, it depends on the type of distributer you have. Here is a link to our communities compatable parts section.   http://communities.msn.com/NissanPatrol ... parts.msnw   Not sure which points are for what, you can still get points from NISSAN only you need the part number... which I also dont have a the moment but can get them if you need them.   Grant
Post by npca-danetteandkeith »
Hey Denny, Acording to the Nissan Engine Model P Service Manual the specs are--- Timing 10 Deg. B.T.D.C.-----Point gap .018"-.021"(.020" is listed in another section) ----Dwell is 35-45 deg. @ point gap 0.5mm (.020")Hope that helps. Keith
ELECTRICAL (NEGATIVE EARTH)FIRING ORDER                    1-5-3-6-2-4IGNITION TIMMING                10°/450 rpm B.T.D.C.DISTRIBUTOR  CONTACT ARM SPRING TENSION    0.50 ~ 0.65kg  BREAKER POINT GAP             0.45 ~ 0.55 mm (0.020")  DOWEL ANGLE                   35° ~ 41° (point gap 0.5mm)SPARK PLUG  DIA. OR THREAD                14mm  REACH OF THREAD               19mm  DIA. OR HEXAGO                20.6mm  SPARK GAP                     0.7 ~ 0.8mm (0.024" ~ 0.028")D.C. GENERATOR & REGULATOR  CUT-IN VOLTAGE                14.5v AT 1600 rpm  NO LOAD VOLTAGE               15.5v AT 3000 rpm  PUSH UP VOLTAGE               9~11v AT 3000 rpm  BRUSH SPRING TENSION          0.36~0.5 kg  BRUSH HEIGHT (STD)            16mmSTARTER MOTOR  BRUSH SPRING TENSION          0.9 kg  BRUSH HEIGHT (STD)            16mm
Thank you both for taking the time to look that up for me.  How do you set the dwell on a patrol dist. I  need some help on getting a new set of points & a Condensor still. Can I get these from Nissan? If so what is the part # ?  I am SO Thankfull to have this club for info. Thank You  ........ Denny
Hey Denny   I took all the info I sent you and posted it in the other section, here is a link   http://communities.msn.com/NissanPatrol ... 5869935822   I just got all the parts from NISSAN about 6 months ago, so they *were* aval, but as time goes on the shelfs get will get empty, in that I dont belive NISSAN is making new parts, just selling what they have left in stock. As for dwell, you will need a dwell metter... I think they still sell them things at car parts stores?   Grant
Locked
