69 rat house
Has thanked: 81 times
Been thanked: 173 times
Re: 69 rat house
Post by nizmut »
So the storm passed through early and the driveway dried out so I did a little work. The goal was to have the front dif in the shop by dark because another storm is supposed to hit in the morning.
So first I had to clean up a space to move all the parts from the right side to on the bench. Then clear a section in the middle of the shop for the dif. Then Haul all the tools out to the Patrol once the concrete mostly dried up.
After getting ready, and double standing the right side because it was all ready taken back to the axle housing(yes I have had jackstands fail before, and a friends brother was killed by jackstands failing), I disconnected the right shock, sway bar, sway bar end link, both stearing stabilizers, and droop stop. Then with the left tire still on I rolled under the patrol and did the same on the left side plus the main brake line and tie rod from the pitman arm. Then I removed the left tire and ball joint so I could haul the tie rods into the shop. I had removed the front drive shaft a Sunday afternoon so that was all ready out. Then with both sides on double stands I removed the u-bolts and straight bolts holding the axle housing to the springs. At this point I put stands under the axle and pulled the front shackles.
Got all the tools picked up and the axle slid out right at dusk. That thing is a heavy pig to get out of there by your self. But in the shop before dark :)
Robin
Re: 69 rat house
Post by nizmut »
Quick locking hub rebuild. I didn't document the disassembly, but will point out the one catch.
Here are all the parts cleaned up
And here are the o-rings I used for the rebuild
The middle sized one is a v seal on the hubs, but I replaced it with a o-ring because sourcing became a pain.
The small and middle sized o-rings go on the brass dial adding a little lube as you go.
Then you flip the dial over and push it in the outer housing.
Then you flip the housing over and set the thin plate over the end of the brass dial, lining up the holes.
Now the threaded cup with the pin at the top left gets a little lube on it and threads into the gear at the bottom left. Then orient the the pin on the center piece and the dowel hole on the ring gear so the threads are flush on the inside with the dial in the locked position.
Now slide the ring gear over the dowel in the outer housing while sliding the dowel on the inner cup into the dial. Tighten down the allen screw in the center and check that the dial turns to both locks.
Now here is the little catch. Before you could disassemble the hub you had to burr out a swedge on the allen screw, now you get to make a new one :)
Robin
Re: 69 rat house
Post by nizmut »
The center part of the hub is simple.
Pull the snap ring, slide out the center, don't lose any rollers, they are free like a u-joint.
After cleanup, pack the bearing race with grease and stack in the rollers. It is easier to load the bearings from this side.
Then flip it over and drop the gear in and install the snap ring.
Another thing I did was chamfer the bolt holes in the outer cap as the lock washers had deformed the aluminum against the bolts.
The large o-ring goes in the groove of the center section that slips into the factory hub.
Robin
Has thanked: 174 times
Been thanked: 408 times
Re: 69 rat house
Post by mad4hws »
Very helpful picks. Thanks for sharing.
Has thanked: 7743 times
Re: 69 rat house
Excellent How-to with pics! :clap: :clap: :clap: Thank you!
Re: 69 rat house
Post by nizmut »
So I pulled the left hub and wheel bearings a few days ago. The hub is in pretty rough shape from someone setting up the wheel bearings with a chisel. That caused the o-ring on the locking hub not to seal, allowing water to enter, and rust to grow. After a lot of wire wheeling I think I can save it, but will need need to do some burr work and a secondary seal option.
So now into the fun stuff. Before you remove these 6 nuts, go buy LOTS of shop towels. First you remove the inner snap ring(You had to remove the outer one to remove the inner part of the locking hub), then remove the nuts.
The backing plate will slide off, then grab the spindle and it will slide off too.
Don't drop the stub axle, once it pivots it will fall out.
Welcome to the lots of towels part. I just slid the stub axle into the spindle and stored it in a safe place that I wouldn't be upset about the mess.
At this point it was dinner time, or any other excuse to not start cleaning that mess out.
Robin
Re: 69 rat house
Post by mad4hws »
looks like chocolate mousse.
Thanks for sharing again. this is going to be very helpful very soon as i start tearing into mine.
Re: 69 rat house
Post by nizmut »
OK, so after we got home from volunteering at the gem show I played in the shop a bit. Started by cleaning up the spindle and stub axle.
Then I pulled the snap ring and removed the roller bearing from the spindle. One of the cheap 4 for $10 pinch bars slid down the spindle can tap out the bearing. I have new bearings so didn't need to be overly careful. The tracta joint is a little rough and will take some cleaning up, but with the locking hubs I'll run it.
After that I pulled all the bolts from the seal retainer, and all the nuts from the kingpin bearing caps. I then used a brass drift and tapped the caps out from the inside. Don't loose the shims! Then grab the outer knuckle and give it a wiggle and the seal will pop out.
I then mucked all the grease out with rags and put it in the solvent pan. (If you are in California, Tractor Supply has a parts cleaning solution that still works)
After the outer knuckle is off it is easy to grab the inner axle and slide it out.
After the axle is out you can do some more grease mucking in the housing.
After I mucked out the housing I tapped out the races, I switched to a steel drift because I have new races and good brass drifts are expensive.
Then I had to go cook elk burger patties for my lunches next week.
Robin
Re: 69 rat house
Thanks for the tip on California solvent. What brand is it?
Re: 69 rat house
Post by nizmut »
RiverPatrol wrote:Thanks for the tip on California solvent. What brand is it?
PSC 1000
Robin
