I would purchase the H knob off of you if you are still willing to let it go. I had my wife look at the set of springs that I still have as per her description I believe they are the rear springs. My front springs were flat as hell so I think I threw them out when I removed them.Timoun wrote:I have a black Bakelite knob with a white "H" on it that came off my '65. If it's the one you need you can have it for the postage... though I would appreciate any help you could give me in locating a front leaf spring.
Assorted 68/69 Parts
- Has thanked: 97 times
- Been thanked: 568 times
Re: Assorted 68/69 Parts
- Has thanked: 56 times
- Been thanked: 39 times
jwgreen wrote:I would purchase the H knob off of you if you are still willing to let it go. I had my wife look at the set of springs that I still have as per her description I believe they are the rear springs. My front springs were flat as hell so I think I threw them out when I removed them.Timoun wrote:I have a black Bakelite knob with a white "H" on it that came off my '65. If it's the one you need you can have it for the postage... though I would appreciate any help you could give me in locating a front leaf spring.
You can have the knob for the postage (I sent you a PM). Thank you for checking on the springs.
- Has thanked: 43 times
- Been thanked: 32 times
Added a rear view mirror to my list. I thought it would be an easy replacement but apparently not. There also is no replacement part listed in the db. Is the oem the only one which bolts in?
- Has thanked: 7741 times
- Been thanked: 2482 times
Here's one that worked: http://60patrol.com/forum/viewtopic.php ... 63&p=13513
Hmmm... if I remember correctly my bolt pattern is different. I think my mount is taller and skinnier with the two lower screws much closer together and further from the single screw on top. I will check it out tomorrow and post a picture.
It doesn't look as though the mirror linked above would match up. Were there multiple mirrors for Patrols? I only see one part number, 96321-c0100.
Here is where my mirror mounts:
And here is the piece it apparently mounts to:
Ok. The mirror you need has a clip that clips into the bracket. Maybe someone from Australia can come up with one for you. Or you might find one in Colombia.
- Has thanked: 257 times
- Been thanked: 270 times
I just received today a used mirror from an individual on EBay.
I searched "ever wing mirror" It was about $7. I could see that it
snapped in like yours does. The arm that snaps in is not the correct
angle for the patrol, but I only needed the actual mirror head. I have an extra
Patrol-correct arm you could have for free if you can find another mirror head.
The head is clamped to a ball on the arm.
Mild Bill
Mild Bill
Thanks Bill. I will look around and get back to you.
Just to make sure that I have it right. The arm snaps into the bracket and the mirror snaps onto a ball on the arm?
There are no known mirrors that bolt up to the bracket's existing bolt pattern?
