Page 2 of 4
Re: Disc brake conversion
Posted: Mon Feb 18, 2019 7:54 pm
by rdarnell
Well I think I will be using Isuzu Rodeo rotors. The distance between the lug bolting surface and the top of the spindle flange is about 2 7/16 inches. The first rotor I tried (2000 4runner ) was 2 1/2 inches deep from back bolt flange to outside surface. The 1977 Land Cruiser measures about 1 9/16 deep. The 2002 Rodeo is right at 2 inches. This will allow room for the adapter to protrude under the rotor without hitting. If I start with a thicker plate I can make the adapter out of one piece instead of tow welded together.
I started my mockup using a piece of 1x8, it is 3/4 thick. I will have to turn the center of the rotor out before I can test fit but so far I like how it looks.
Posted: Tue Feb 19, 2019 9:46 am
by mad4hws
This is looking good. Woodworking and Metal skills. I am envious.
Posted: Sun Feb 24, 2019 6:54 pm
by rdarnell
I am back with better results this time. I am using 1993 Toyota 4Runner calipers with 2002 Isuzu Rodeo rotors. I started this build with a piece of 7/8" hot roll that was 6" x 7". My finished piece was .600 thick so I could have started with 5/8 stock. The outside measurements are 6" x 6-5/8".
Posted: Sun Feb 24, 2019 7:02 pm
by rdarnell
Posted: Sun Feb 24, 2019 7:12 pm
by rdarnell
I needed to open the center of the rotor and square up the backside too. I then re drilled the lug holes to 19/32, I wanted to keep them as snug as possible.
I had to do some trimming of the 4runner brake pads as they were hitting the scratchers.
Posted: Sun Feb 24, 2019 7:44 pm
by rdarnell
Posted: Sun Feb 24, 2019 9:04 pm
Posted: Mon Mar 04, 2019 12:05 pm
by rdarnell
Posted: Wed Mar 20, 2019 8:43 am
by Volkmann77
I could utilize your skills turning wrenches.
Posted: Thu May 09, 2019 2:14 pm
by yitzac1990
do you think you'd be able/kind enough to post a "final" parts list of all that you used to do this? rotor part numbers, caliper part numbers, steel stock sizes for custom bracket, etc...would be much appreciated!
