Well, after changing plans for the body mid-project; I spent this past weekend re-arranging my parts donor rigs, and got the body totally torn off the red 65 donor; and I rolled the green 66 back out into the boneyard (I need to stop calling it green- There isn't much green left on it. I should call it "the bondo 66" hahaa).
I really like the fact that I can use this body on the 65 restoration now-
1) It's a 65 body, going onto another 65 Patrol
2) It is in WAY better shape than the green 66's body (let's be frank here - Even after the 300+ hours I've put into that green body, It still shows the evidence of being bashed on its whole life, while this one is
pristine)- There is ZERO bondo underneath that thick red paint... It's all straight, native Nissan Patrol steel- The 66's body belongs on my desert beater (which is where it's going to be shortly
3) Even though it's red- This one was actually also
white originally, so how cool is that? I'm replacing a rusted out white 65 Patrol's body, with the body from another originally white 65 Patrol. can't get much more correct than that...
And yesterday, I got a VERY pleasant surprise - Someone didn't pay very good attention to their product data sheets in the past... As soon as I hit the fender with the pressure washer, both layers of red paint, and a layer of yellow polyester primer between the two reds, started peeling off in flakes, leaving just an old layer of brown sealer (probably enamel) exposed.
There is nothing beneath the brown except the factory white, on top of the factory gray, on top of the factory red oxide primer, on top of clean, beautiful steel.
I sure hope the tub strips off this easily- I'll be in heaven. Water is a lot cheaper than sand paper, even out here in the dry west
