SOA
Posted: Thu Apr 22, 2004 1:03 pm
by npca-eyepez
Well, finally I am ready to post some pictures of my spring over axel conversion. I also have revolver shackles, and the conbination works great. If you need for flex, go with the shackles. If you need more clearance (like I did), go with the SOA. The later involves much more work and a few mods, but it is worth every headache. I finally have my Patrol the way I want it. I will also post some pictues of a couple of interesting things I've done to the car, such as dual battery with isolator and in-cab winch controls. If you have any questions please ask me. Keep them running.
SOA
Posted: Fri Jun 18, 2004 6:51 am
by npca-toine
Hi EyePez,   I'm planning to do a SOA on my patrol 3.3D but have a lot of questions, I hope you can answer.   How dit you modify the front/rear axle? Did you have to replace the drive-shafts or can you keep using the original ones? When you do a SOA, doesn't the front driveshaft touch that horizontal part in the frame that's in front of your gearbox? All pictures of your modification and tips are more than welcome!   See you, Toine
SOA
Posted: Fri Jun 18, 2004 2:07 pm
by npca-eyepez
; Hello Toine,; Doing the SOA was fairly simple and straight ; forward. I didn't have to replace nor modify axels and drive shafts. The thing ; is, since I installed revolver shackles at the same time, I don't remember if ; certain mods were nesessary because of the conversion or because of the shckles. ; In any case, I had to lengthen the brake lines and relocate the steering. I also ; removed the smallest leaf on the front springs and two in the back, mainly ; becasue it rode too high and stiff, because I had just installed new gas shocks. ; I posted some  pictures on the club site, but I'b be happy to write in ; detail the whole procedure, and include pictures if you give me a couple of ; days. Let me just tell you that the SOA conversion was the best mod I've done. ; Off road it peforms 100% better than before, at least in the type of terrain I ; usually go wheeling. I'm very pleased with the results, and I know you'd be ; too.;  ; I'll write in a couple of days.;  ; ; ----- Original Message ----- ; From: ; Toine ; ; To: Nissan Patrol Club ; Albuquerque ; Sent: Friday, June 18, 2004 5:51 AM; Subject: Re: SOA; ; ; ; ; New Message on Nissan Patrol ; Club Albuquerque; ; ; SOA; ; ; ; Reply; ; ; ; ;  ; Reply to Sender   Recommend ; Message 2 in ; Discussion ; ; ; ; ; ; From: Toine ; ; ; Hi EyePez,;  ; I'm planning to do a SOA on my patrol 3.3D but have a lot ; of questions, I hope you can answer.;  ; How dit you modify the front/rear axle?; Did you have to replace the drive-shafts or can you keep ; using the original ones?; When you do a SOA, doesn't the front driveshaft touch that ; horizontal part in the frame that's in front of your ; gearbox?; All pictures of your modification and tips are more than ; welcome!;  ; See you,; ToineView other groups in this ; category.
SOA
Posted: Sat Jun 19, 2004 8:14 pm
by npca-sledheadak
go to www.outerlimits.com and goto the members or nissan section.there is lots of info on doing a soa.i just started mine on a lwb mq and so far so good.
SOA
Posted: Mon Jun 21, 2004 5:07 am
by npca-toine
I'm really looking forward to receive your mail!   Thx in advance   Toine
SOA
Posted: Wed Jun 23, 2004 4:53 am
by npca-andrewoooohhhh
Our great outerlimits site is actually www.outerlimits4x4.com Have a look at V8 patrol or screwy screwball's
SOA
Posted: Wed Jun 23, 2004 12:35 pm
by npca-fud
and a great site it is...or forum. If not reading about nice trucks and how they are built on there i find myself reading some very funny threads. OuterLimits is the best forum I have found on the net!
SOA
Posted: Wed Jun 23, 2004 4:02 pm
by npca-sledheadak
lol sorry about that..great forum with lots of info on the patrols...
