Water Pump
Locked
Water Pump
Post by npca-vbt3 »
Surely someone has had to replace a water pump.  I have a '66 Patrol and the water pump is on its last leg.  My Patrol is the only way I have to get to work (only about 5 miles) so I need to fix it quick before it dies.  Any suggestions on part # matches or something would be helpful.  Thanks.
Water Pump
Post by npca-gary »
The Nissan part number for the pump is; 21010-58050. a good NAPA or other parts house should have a cross reference to a replacement pump.  My parts book show that the pump is rebuildable. The bearings are available but you will have to remove them to get a part number or to measure them for replacement.   Good Luck
Water Pump
Post by npca-gary »
I forgot to add that I got mine from a Nissan dealer. (the older the dealer the better) or check with Nissan autoparts.com
Water Pump
Post by npca-jagman »
           Hello .     I know its been sometime since you posted the add fo a water pump...I have a good rebuildable pump.... I have a palce that can rebuild them in short turn around time....I f yo ustill need on let me know...Mike Miller ...........ajagman@hotmail.com
Water Pump
Post by npca-daner »
 i was able to rebuild my fuel pump- i wanted to at least try before forking over $191 to the local nissan/mafia. the bearings in mine were Federal 1302-f. i assume the pump had been rebuilt before as these are made in U.S.A. the ones i replaced them were SKF6302 2rsjem.  i opted for the sealed bearings, but non sealed are available also, must be a common size as the industrial suppley house had them in stock, $20. rebuilding the pump is not terribly easy, the main shaft is brass, DO NOT BEAT ON IT! it will not want to come out easy either-but i didnt want to fork out almost $200. as a note, i tried going through nissan industrial forklift warehouses, but after much research, the prices were consistantly higher than nissan-good luck!
Locked
