Chassis or Frame to scale
Posted: Tue Apr 30, 2013 9:13 pm
Edit: Replaced the drawing with a more convenient scale.
I've always wanted to have the diagrams from the service manual to a meaningful scale. The following is a first attempt into it, with the Chassis or Frame.
I scanned the diagram, and then modified the scale. This document when printed at 100% size, will produce a scaled drawing of the chassis.
The scale is 1:20
This means that 1 unit in the paper, represents 20 units in real life. So 1"=20", or 1mm = 20mm.
I guess this diagram will work for both. types of units
When printing the PDF, make sure to choose Scaling type: none, so the drawing prints correctly.
I would like your comments, to see how we can improve this. I can erase all the measurements in millimeters noted in the original drawing and replace it with the corresponding in inches.
The scale is 1:20
