Transmission input shaft (retainer) seal
- Has thanked: 652 times
- Been thanked: 632 times
Transmission input shaft (retainer) seal, NAPA part # 13568 $13.00
this seals inside diameter is perfect, the outside diameter is too small. This seal will still work, the original seal is a two piece, so if you leave the outside diameter piece of the original seal in the retainer, this seal will press into it perfectly. I know it sounds crazy, but it works.
Re: Transmission input shaft (retainer) seal
I just received the retainer seal that i ordered off ebay 35/55/8 double lip seal. Its a perfect fit.
- Has thanked: 181 times
- Been thanked: 174 times
Still available from Nissan. Part number is 32119-43800
Cheers
Cheers
