The other Week the old girl Developed a misfire, I diagnosed it to #4 Spark Plug, so I chucked in a spare Plug I found lying in the shed, and it temporarily fixed the issue. Then Last Friday I Was going over the road to help the lady pull out some, I had to go retrieve some cable from the paddocks, it became missing again and on the way up the paddocks, when I got back to the house, I pulled out #4 Spark Plug and chucked in another one, it made it better but not 100% perfect.
Its not getting any better, it is quiet a miss fire somewhere in the system, I have swapped out the Leads for some I got from a Wreck (Yes they may be dicky, though they may Still be ok)
A Couple of other points as well
- It has relatively new spark plugs in it
- It having some wiring faults at the moment, maybe some part of the issue
- It used to start first go even on Really cold mornings with a fraction of choke, and a couple of pumps of the throttle, and it fired up and purred like a kitten, Until Its been misfiring its never started first go
Things I think may be worth doing
- New Plug leads
- Check Coil
- Check Dizzy Cap and rotor button
I don't want to spend money if I don't have to, its a basher but it needs to be reliable, overall its been awesome so far, few little issue but nothing has stopped her.
Any ideas or Suggestions will be awesome as, thanks in Advance
