I heard back from my transmission guy, and it seems I have two major problems: my gears were sitting in a milkshake of oil and water for quite a while, and as a result, all the transmission gears are pitted pretty badly. I also have missing teeth from some of my gears.
So... I'm looking for either a gearbox that will work on a '67, or just the gears from an existing gearbox (since shipping the whole thing will cost a small fortune).
If you have anything, please let me know!
WTB: Transmission or trans gears
- Has thanked: 652 times
- Been thanked: 632 times
Re: WTB: Transmission or trans gears
What gears do you need exactly? I do not have an input shaft, but i might have some of the others. Im not positive i can help, but if i know what you need for sure i will double check my stash and let you know.
Missing teeth usually means input shaft and counter shaft gears.
I found a spare countershaft yesterday, but i wasnt able to inspect it thoroughly. Im pretty sure its good though. If this is a part that you need let me know and i will pull it out and take a closer look.
- Has thanked: 49 times
- Been thanked: 141 times
2869ral wrote:I found a spare countershaft yesterday, but i wasnt able to inspect it thoroughly. Im pretty sure its good though. If this is a part that you need let me know and i will pull it out and take a closer look.
To be honest - I'm not sure which gear is missing teeth - I only got this picture from the transmission guy taking it apart:
I had problem with not being able to downshift, so I assumed it was my baulk rings. Apparently those look fine, but the rest of the gears are very pitted. His suggestion was to either put it all back together and run it until it breaks, but since everything is pulled out at the moment, I might as well track down some parts.
zed PM'd me and let me know he has an entire transmission
That pic is of the synchro ring. Please dont get rid of the old trany, im sure there are many salvageable parts in there that someone may need. I may need that input shaft if you ever let it go.
