Fuel Tank Restoration
- Has thanked: 13 times
- Been thanked: 23 times
Dropped the fuel tank and have begun to restore and clean her up. I have been using a electrolysis method for the last week to try and get what rust I can out of the inside. This weekend I will further clean and seal the inside with the POR 15 kit.
- Has thanked: 84 times
- Been thanked: 327 times
Re: Fuel Tank Restoration
Good stuff. I'm keen to hear how you go. My tank is causing me grief at the moment!
- Has thanked: 7709 times
That's an interesting method to use. Can you provide more detail?
Your tank looks to be in pretty good shape.
The electrolysis method I used was to mix 1 tablespoon of washing soda (sodium carbonate) per gallon of warm water. Fill the tank with this solution and then suspend a piece of rod iron in the tank, you must insure the rod does not touch the tank. Then connect a battery charger on trickle charge to the tank, positive end on the rod and negative end on the tank. Every day you need to remove the iron rod to clean all the gunk and crude that builds up on it. It is a great method.
- Been thanked: 136 times
I put a couple hand fulls of clean pee gravel into my tanks with half a gallon of cleaning solvent then and did a whole lot of shaking. Worked real good.
- Has thanked: 203 times
- Been thanked: 678 times
Alternatively, put a long chain and shake the tank. Removing a linked chain may be a bit easier than shaking out gravel.
Getting the peewee gravel out was not a problem. It did work really well. If I remember right it was a old duffer that gave me that advice.zed wrote:Alternatively, put a long chain and shake the tank. Removing a linked chain may be a bit easier than shaking out gravel.
zed, just noticed your in Plano, Texas. I have a couple aunts in Plano. I'll give you a shout when down there some time in April or May?
Let me know when you are in town.
- Has thanked: 646 times
- Been thanked: 1149 times
I've been thinking that a new tank might be easier that trying to restore the existing one. Our tank has been lined to protect the fiberglass patches that are on the fiberglass patches covering the rusted holes.
At least the tank's shape is pretty simple so how hard can it be? Here's what's inspiring me anyway...
http://www.hotrod.com/how-to/engine/091 ... -gas-tank/
Finally got the fuel tank mounted last weekend and thought I would post some pics.
