Page 1 of 2
Datsun 311 Reflectors on Ebay
Posted: Fri May 01, 2015 1:19 pm
by moore_rb
RMP&O has already confirmed that Datsun 311 reflectors are a cross-match to early 69 (leftover 68) and older Patrols...:
http://www.60patrol.com/forum/viewtopic ... 70&p=27377
well, here are some NOS 311 Everwing reflectors on Ebay:
http://www.ebay.com/itm/Datsun-Roadster ... 1304874302
NOTE: The chrome base on these is wrong for the Patrol - Only the lense is correct. Early 66 and older Patrols used a raised, solid rubber platform base with a chrome bezel:
and late 66 to early 69's just used a flat rubber gasket between the reflector and the body of the Patrol...
Re: Datsun 311 Reflectors on Ebay
Posted: Fri May 01, 2015 7:44 pm
If I remember correctly, the red reflector actually pops out of the chrome bezel on these. It has the same clip as the '66s do on the back, so it just clips in to the chrome bezel.
Posted: Mon May 04, 2015 11:00 pm
by offroadkid
moore_rb wrote:RMP&O has already confirmed that Datsun 311 reflectors are a cross-match to early 69 (leftover 68) and older Patrols...:
WHOA!!!! Those eBay ones are out of the town I live in!!
Posted: Tue May 05, 2015 8:21 am
by moore_rb
Then you can save 5 bucks on shipping... !
Posted: Tue May 05, 2015 10:33 pm
by 50car
When you expand the picture on ebay, you can see that the "refrector " shown is an Everwing A7002. This is the same part that I have in all the reflectors I have ( over 10).....
Posted: Tue May 05, 2015 10:49 pm
by offroadkid
But they're not for the 66's?
Posted: Tue May 05, 2015 10:55 pm
by 50car
The items on ebay appear to be the correct ones.
Just need to split the reflector from the base. Easy enough to do as they are just a friction clip that holds the two pieces together. Toss the base or resell to recoup some of the $$ you spent....
Posted: Tue May 05, 2015 10:58 pm
by 50car
I should say they are correct for later year 66s. Where is your vehicle serial number in relationship to my 66 listed in registry? My 66 has the everwings.
Posted: Tue May 05, 2015 11:04 pm
by offroadkid
50car wrote:I should say they are correct for later year 66s. Where is your vehicle serial number in relationship to my 66 listed in registry? My 66 has the everwings.
I'm L60-06990, you're 073xxx & 076xxx. Does that put me in the same set up as you? I have 2 rectangular holes under each tail light that I assume are for the reflectors.
Posted: Tue May 05, 2015 11:10 pm
by 50car
Exactly. Those small rectangular slots are for the reflectors. My earlier ones are just small round screw holes. The raised rubber edged ones just had a screw tru the back in the middle
