Steering Damper
Has thanked: 173 times
Been thanked: 306 times
Steering Damper
Post by Peter60 »
I put a new steering damper on my Patrol the other day.
I was amazed at the improvement in steering. Before I need to continually make slight adjustment to keep the Patrol going where it should be going. Now with the damper I no longer needs to make these adjustments :D
When out 4WDriving, the wheel no longer shakes and rattles like it did.
Its $40AUD well spent :D
My damper is not 'self centering'. This what I installed.
KYB Damper. Part no KS1003
Has thanked: 6031 times
Been thanked: 1610 times
Re: Steering Damper
Peter60 wrote:...
Glad you felt all that difference. Thanks for posting this.
From an initial search, it's not available here in the USA. But I recall some member years ago installing another KYB damper
Been thanked: 14 times
Re: Steering Damper
Post by dustin3n »
Sounds like a good choice. How's cornering response?
Re: Steering Damper
Post by Peter60 »
I didn't notice any difference in cornering response. I'm not sure if that the dampers job.
