Hood Bump Stops
Posted: Tue Nov 13, 2018 9:36 am
by CBlake
Is there a suitable replacement for the hood bump stop? I think there are 6 of them that push into holes on the underside of the hood where it meets the fender.
Thanks!
Re: Hood Bump Stops
Posted: Tue Nov 13, 2018 10:07 am
I've used these in the past:
Hood stops
Re: Hood Bump Stops
Posted: Wed Nov 14, 2018 11:05 pm
by rjiggy
If you are referring to the all rubber stem bumpers that push into the holes on the bottom flange of the hood, I used these from Steele Rubber Products:
https://www.steelerubber.com/gravel-shi ... 33-0016-45
They fit in a 3/8" hole. They also worked great on the bottom of the rear jump seats where the seats rest on the rear wheel wells.
This was on a true 69' model. Not sure if they would be the same for earlier years.
Re: Hood Bump Stops
Posted: Thu Nov 15, 2018 10:36 am
Cool! I've added this to the compatible parts list.
Re: Hood Bump Stops
Posted: Mon Nov 19, 2018 5:38 pm
by CBlake
I bought a mix of bumpers on amazon, so I'll report on those as well.
Thanks!
Re: Hood Bump Stops
Posted: Fri Nov 23, 2018 10:07 am
by CBlake
The amazon ones didn't work so I ordered the Steele ones. Thanks for the recommendation!
