Parts Wanted for PatrolP1 Patrol Build
Been thanked: 1988 times
Greetings,
PatrolP1 is in better mechanical shape than my previous projects so the parts needed will not be too extensive. Please check your inventories for the following parts for the 66 refurbishment:
a). Good Steering Wheel
b). Light Knob - Screw in Type
c). New Interior Door Panels
d). All Suspension Bushings
Your help is always appreciated and I will be glad to pay any fair price.
Patrolling with PatrolP1,
Re: Parts Wanted for PatrolP1 Patrol Build
Just in case you didn't see it the first time.
Has thanked: 7703 times
Th slight knob or switch he needs is for a '66 or earlier Patrol. The later switched used a set screw to secure the knob, the early ones were screwed on and had a set screw.
Has thanked: 264 times
Been thanked: 776 times
Post by plateaucal »
David Bro',
Check the many boxes of goodies I gave you. Pretty sure there are some knobs and switches in there.
Thanks Plateaucal, I’m pretty sure I still have some. I just can’t recall if I put one on Phoenix Patrol or if it is an early screw in type Light knob. But believe me I’ll be digging for gold when I get back up there.
Thanks again,
Steering Wheel - Refurb Shop
Greetings,
Punkin/P1 will need a major steering wheel refurb or an early replacement steering wheel from this forum. The only shop we have found so far isn't capable of the required work. If you have one that just has separations in the hand wheel then let me buy it from you, those can be fixed. If you know of a shop that can fix major cracks and damage, then please send their contact info my way.
I have paid to rehab three gauges and I know rehabbing parts like these can be real expensive so I'm starting early for a replacement wheel or a reasonable price to repair the existing.
Thanks again to all,
All are found.
