Someone should do a 'How to' on the brake master
Has thanked: 310 times
Been thanked: 176 times
Re: Someone should do a 'How to' on the brake master
Post by bosque »
RiverPatrol wrote:
bosque wrote:Did you try this dude in CA? He was way more doable than WhitePost.
http://www.brakecylinder.com/sleeve1.htm
The web site says they are no longer doing business. :|
Ah. He did say he was getting hammered by the economy.
antiquecyles wrote:After searching, talking, typing, calling and praying...
Are you kidding me? I find it at Napa? The rebuild kit with piston is $22 bucks! I have to drive 15 miles to the nearest location that actually has it but a small price to pay! Wow. Im gonna bring the old one to match up but it "looks" exact.
Thanks to a compatible parts list-Jim Morrow (THANKS!)
Part # is UP 387. It says it fits 61-66 Ford E-100 1/2 ton vans and wagons. Maybe they just forgot to include the Patrol :)
yahooooo!
How in the world have we misplaced this? Venturing out of our comfort zone brings new options ...and it takes the amperage of a newbie to try and .....hey......hope it prevails. We'll need pics and graphic info and you'll be promoted to Master Cylinder Sargent or something. :roll:
Has thanked: 38 times
Been thanked: 30 times
Post by antiquecyles »
yahooooo!
One day I hope to be a Patrol Sergeant/General! I have went from knowing ABSOLUTELY NOTHING about Master Cylinders to being "somewhat" knowledgeable in the area. I promise to report back all my findings along with pictures and pointers.
:) Kris
Has thanked: 97 times
Been thanked: 568 times
Post by jwgreen »
Kris,
Did you ever figure out your Master Cylinder situation?? Did the rebuild kit work??
jwgreen wrote:Kris,
Hell yes it did! It was a joke! I spent so much time on this only to find out that it was super easy to do.
You gotta call me when you're gonna do this (951 609-7554) but read through the replies. There are pictures from other members who sent me pics. The kits you will find for 15 bucks have all the rubbers, springs and cups that you need. you will have to use your existing piston. Just clean it good. I highly reccomend you hone your cylinders before rebuilding them otherwise you will be repairing them again soon. You can get a honing bit for 6 bucks at Harbor Freight. Just attach to your drill and push it through about 50 strokes. Sharpens the cylinder up nicely.
be sure to use clean brake fluid on the pieces when you reassemble.
kris
Has thanked: 7703 times
Been thanked: 2480 times
The wind was blowing again today so I decided to clean off a work bench. Among the forgotten treasures I found there was a brake master rebuild kit. It is aftermarket, but it is the correct kit. Problem is, it comes from either Japan or Russia, according to Google. The brand is Miyaco, the part number is MK-40582. When I Google MK-40582, I think I could end up buying some small nuclear weapons. I'm sure I'm on NSA's watch list now.
So, this never really evolved into a workable "How to" with a conclusion that is easy to reach.
Has thanked: 652 times
Been thanked: 632 times
Post by Coyote Patrol »
Here is a rebuild kit that fits the Patrol perfectly, even the piston.http://www.ebay.com/itm/1965-1966-Corve ... 68&vxp=mtr
Has thanked: 12 times
Been thanked: 36 times
Post by sleepyzzz »
2869ral wrote:Here is a rebuild kit that fits the Patrol perfectly, even the piston.http://www.ebay.com/itm/1965-1966-Corve ... 68&vxp=mtr
mmmmmmmmmm corvette parts in a patrol. will that make it go faster? :lol: thanks for the heads up. wow you sure have a lot of knowledge and skills. wish you were closer to NW AR where i could come over and learn a little first hand.
1967 SPL 1600
2013 Nissan Rogue
2001 Nissan Sentra SE R
Has anyone tried a master cylinder from a 240, 260, or a 280Z? The mounting holes look very close. The bore is 7/8 but its also a dual master cylinder. :think:
The Wilwood dual master that I have recommended before is for the early Z cars. It bolts right up if you get the one that is already modified for the Z.
Has thanked: 10 times
Been thanked: 17 times
Post by Keith »
Keith Y. (npca-Danette&Keith)
