Heater Warm Up Time
Has thanked: 42 times
Been thanked: 73 times
Heater Warm Up Time
Post by EricB »
Hi all
Now that it's "cold" again here in SoCal, I was wondering is it just me or does the air coming out of the passenger heater box take forever to warm up?
The coolant for the engine will get to temperature in a normal amount of time on a cold morning so why wouldn't the heater box follow suit ? Why would there be a delay - not really making sense to me ...
Thoughts?
Thank you
Has thanked: 529 times
Been thanked: 301 times
Re: Heater Warm Up Time
Post by 50car »
Is the heater line valve on the rear side of the head opened up? If you follow the heater hose from the heater to the side of the headyou will find where the valve is located.
Jeff
50Car
Has thanked: 181 times
Been thanked: 174 times
Post by RMP&O »
clogged heater core?
Post by EricB »
Hi guys
sorry for the newbie question ...
I hadn't thought about the valve at the back of the head ... I thought it was open - but with a little convincing I was able to open it up quite a bit more - it was only letting a trickle get into the heater core - so never mind then ...
Thank you for your help
onwards!
-e
Has thanked: 7741 times
It was in the summer position. ;)
Has thanked: 49 times
Been thanked: 141 times
Post by ckhorne »
RiverPatrol wrote:It was in the summer position. ;)
I had been meaning to ask if that valve can be closed off without causing engine overheating. I presume this means it can be safely closed?
Yes. The water that flows through that valve is only for the heater. Patrols without heaters don't have that valve.
