Large (Aussie) Size axle Nut
- Has thanked: 6 times
- Been thanked: 1986 times
The Aussies received a beefier version of the 60 in some respects. One of those versions included larger axles. I knew that but plowed ahead hoping the axle hub nut I purchased of Ebay was of the smaller US version....since no specs were offered.
Naturally I was zonked...again.
Therefore, if any of you need a large size rear axle interior hub nut I have one with freight I paid $100.
- Has thanked: 514 times
- Been thanked: 631 times
Re: Large (Aussie) Size axle Nut
I remember seeing one offered on ebay in the past for a 720 datsun pickup. do you know if they would be closer in size.
Thanks Richard, These things I don't know but I'm sure a couple of the Patrol whisperers do. I bet we hear from them.
I will try to measure the threads on my axle and see what I come up with for the size.
- Has thanked: 6010 times
- Been thanked: 1600 times
I have saved from years ago what somebody did to remove and tighten the nut. He purchased Spindle Nut Wrench W1271 that's intended to be used in front hubs, cut the upper portion in order to reveal a cylinder that will slide over the axle, and then welded two arms for leverage. The pictures I saved are not that good, but you'll get the idea. In the following picture on the left you see the spindle nut wrench with the upper part of the body removed, and on the right the arms welded to the remaining portion. The idea is to mimic the special tool called in the service manual. And by the way, there's not a single mention of this special tool for the light duty axles that we have. The only reference is for the heavy duty axle that Aussies have.rdarnell wrote:I will try to measure the threads on my axle and see what I come up with for the size.
The spindle nut can be purchased at Summit Racing: https://www.summitracing.com/parts/wmr-w1271
David, if you decide to go this route, please take some pictures of your progress. Good luck.
that is kind of what I thought about making to remove. I wonder if the nut that that socket was intended for would have similar thread?
Richard, if you just measure the axle that maybe the HD version and it is larger than standard duty then it will fit. I think they only had two sizes.
Esteban. That tool explains why all the nuts i've seen are so chewed up, nobody over the years has had a tool like yours!
Ron from AZ is sending some more parts and the shims we apparently need. Next week King Kong Craig will take another stab at Presidio Patrol's rear hubs.
On another note, it seems there is a shortage of good backing plates. I'm thinking about having some made after I run out of essential projects. They shouldn't be too hard, just need to get some pricing.
Patrolling to our local Rotary Club meeting today. I'll park the CCV6 (white soft top) in front as we are giving a presentation
to raise money for our non profit well drilling and trade school project in Victoria Falls. Hey already were gifted with $30,000 this week, looking for more.
Patrolling with a purpose,
Interesting thought!rdarnell wrote:that is kind of what I thought about making to remove. I wonder if the nut that that socket was intended for would have similar thread?
The problem will still be how to implement a lock washer in that case. I don't think there's enough thread in the axle to run two nuts.
This is what I found: https://desolatemotorsports.com/shop/su ... rsion-kit/
In the Summit Racing page one person has used the spindle nut wrench in a front axle Dana 44 application.
might be able to either use a larger locking washer and then flatted to the hex side or turn the nut down and reindex the notches in the nut.
