Name that part!
- Has thanked: 7744 times
- Been thanked: 2482 times
Re: Name that part!
Correct answer!bosque wrote:Backside of vent....under dash....inside glovebox.
Good one!
- Has thanked: 6029 times
- Been thanked: 1608 times
Re: Name that part!
Maybe I'll be embarrassed again... but I don't think it's an original part.
Maybe for a US spec Patrol.
- Has thanked: 310 times
- Been thanked: 176 times
Re: Name that part!
If any of us are not embarrassed again then we are just hiding from learning more by sometimes making mistakes. Is this a proper sentence?Esteban wrote:Maybe I'll be embarrassed again... but I don't think it's an original part.
I am sure it is a Patrol part....of a part.
Re: Name that part!
bosque wrote:If any of us are not embarrassed again then we are just hiding from learning more by sometimes making mistakes. Is this a proper sentence?![]()
You're becoming the resident Philosopher at 60Patrol! The only thing that I can think off is in this picture.
Re: Name that part!
I chuckle at philosophy.
I can give another hint.....it has to do with the fuel line end.
Re: Name that part!
Really good one!!
I knew I was wrong after I posted and wanted to mention, but I don't see how to edit a post.
Re: Name that part!
In the upper right corner of your post you should have and 'Edit' button, like this:Esteban wrote:...but I don't see how to edit a post.
If you don't have one you might check your browser settings or try a different browser.
I was originally thinking it was a lock cover, but the door lock covers are teardrop shaped. BTW - I cam across a kit on the Internet somewhere to fix these covers when they fall off the gas cap like this. If anyone is interested I will look for it again.
